GeoLink Hibajelzések
Revision as of 08:43, 23 August 2020 by PSzakra (Talk | contribs) (Created page with "Folyamatos felvillanások")
Probléma esetén a GeoLink a LED villogásával értesíti a pilótát. A LED ismétlődő villogása minden hibát kijelez. Törések után a GeoLink javítását is el kell végezni, ha szükséges.
A LED villogása a bekapcsolás után azonnal megjelenhet. A felvillanások száma mutatja meg a fennálló problémát.
1 Hiba jelzések
1.1 1 x felvillanás
Stored hardware data in GeoLink were lost. Contacting Spirit System support is necessary.
1.2 2 x felvillanás
Pressure sensor is not operating correctly. Usually this problem occur when GeoLink is operated for prolonged time under extremely high humidity conditions. Store GeoLink in low humidity environment for few hours until internal condensate will evaporate. If this will not help contact Spirit System support.
1.3 3 x felvillanás
Gyro, accelerometer sensors are not operating correctly. Contacting Spirit System support is necessary.
1.4 4 x felvillanás
Compass sensor is not operating correctly. Contacting Spirit System support is necessary.
1.5 Folyamatos felvillanások
This might happen rather in-flight and could signalize unexpected failure. Most probable reason is shock by high electrostatic discharge. This will result in the GeoLink connection is broken event and loss of GeoLink functionality from the moment it will occur.
2 Other notifications
2.1 Calibration process
If you can see 3 series of fast flashing (followed by fast erratic blinks) after power up of the GeoLink then the module is in so called Calibration process. This process can be invoked by pilot through the Spirit Settings software and must be finished according instructions. Until finished the GeoLink will be inoperable. Spirit Settings will display Not connected message until the calibration is finished.
