SpiritRS Előkészítés
Revision as of 10:43, 23 August 2020 by PSzakra (Talk | contribs) (Created page with "A támogatott rádiók a következők")
A Spirit RS egység működtetéséhez bármilyen JETI DUPLEX rádió felhasználható.
  • DC-14
  • DC-16
  • DC-16 II
  • DC-24
  • DS-12
  • DS-14
  • DS-16
  • DS-24
We recommend to start with clear model profile as you will need only few changes.
Spirit System offer DS-12 radio tailored specially for the Spirit RS. This mean you will be able to utilize completely all features out of the box.
1 Beginning
2 Turning On and Off
3 New Profile
In the Basic Properties menu select Heli to Spirit and continue to another page. (Please note transmitter update 5.04 is required for this option - only available in DS-12 Spirit Edition at the moment).
4 Basic Helicopter settings
4.1 Flight Modes
Info.png Non-Spirit Jeti radio might need to get extension module for Flight modes (from swshop.jetimodel.com). Alternatively you can use only 3 Flight modes.
Info.png Instead of Autorot. flight mode you can set Throttle Cut switch.
4.2 Throttle Curve
4.3 Pitch Curve
4.4 Gyro Gain
For the beginning you can use these values. Positive value will activate Head-Lock Gyro mode, while a negative value will engage Normal (Rate) mode.
For further Gyro Gain tuning you can set 50, 60, 70% gains or assign a potentiometer.
