Hott Integráció
Revision as of 21:15, 26 August 2020 by PSzakra (Talk | contribs) (Created page with "Az integráció minden HoTT vevőkészülékkel és rádióval működhet, kivéve az MZ-4 és az MZ-8.")
A 2.3 verziótól kezdve a Spirit egységek teljes integrációt támogatnak a Graupner HoTT adóval. Ez azt jelenti, hogy konfigurálhatja a Spirit egységet teljesen a rádióból származó parancsokkal, számítógép nélkül.
1 Wiring
To allow the integration you have to connect additional cable to your current setup. This cable will connect the Telemetry port of the receiver with the SYS port of the unit. So there should be two connections between unit and receiver for:
  • Channel transmission (PWM, PPM or SUMD)
  • Telemetry and Integration data
Use the Hott Integration cable available in our eshop. Connect it according the following steps:
  1. End with black servo connector should be connected to the receiver on the Telemetry port marked with T label.
  2. End with red servo connector should be connected to the SYS port.
Warning.png It is very important to pay attention during the connection!
If connected wrongly, it will damage the unit permanently. The cable end where red wire is in the middle pin must be always connected to the unit. Never use other cables for this connection!
Info.png Servo connector in the Graupner Hott receivers is connected so that the signal wire is at the bottom.
2 Receiver configuration
In your transmitter, go to the Function (F)/Telemetry/Setting & Data View where you have to change option SENSOR at CHx to YES.
3 Entering the menu
Graupner MZ-18 - Integration menu
Graupner MZ-18 - General page
4 Sensor Emulation
Available types are:
  • GAM - General Air Module
  • EAM - Electric Air Module
5 Telemetry data
  • Fuel [%] - Vibration level (Reported as Fuel and ALT in the GAM sensor)
  • BAT1 [V] - Main Battery Voltage
  • Current [A] - Main Battery Current
  • Capacity [mAh] - Main Battery Consumed Capacity
  • BAT2 [V] - BEC Voltage
  • T1 [°C] - ESC Temperature
6 Usage
Info.png Do not forget to click the Save Settings when you want to save the changes permanently.
Info.png Before flying press the ESC button to exit the integration menu.
