Graupner SUMD/hu
Revision as of 19:36, 27 August 2020 by PSzakra (Talk | contribs) (Created page with "Bekötés")
A Graupner HoTT rádiókkal teljesen digitális, egysoros SUMD protokollt használhat. A csatlakozáshoz csak normál szervó kábelre van szükség.
1 Bekötés
Connect the cable according the photo. In the unit the cable is in the RUD port. In the receiver it is always the last channel. For GR-12/GR-12L it is output with label 6.
Info.png Please note that the signal wire (Orange) is at the bottom of the receiver.
If you have not connected a power supply, you can connect the BEC cable or 1-2S LiPol now (even without a servos).
Warning.png Never connect a power supply to the SYS or ELE/PIT/AIL ports!
2 Spirit Settings
After initialization of the unit you can start the software. To allow the connection set the Receiver type to SRXL/SUMD in the General tab.
Now save the settings (CTRL+S) or in the Backup tab/Unit - Save.
3 Receiver configuration
By default SUMD transmission is disabled in the HoTT receivers. It is necessary to enable it in the (F) Function/Telemetry/Setting & Data View menu (HoTT MZ series).
Change SUMD at CH6 to YES.
4 Usage
Now you can restart the unit. After the initialization the SUMD connection will work. Reverse of some channels might be necessary depending on the radio model - please check the Diagnostic tab.
The transmission is able to carry all the channels. Usually SUMDOF12 option (if available) is fine.
Info.png For MX-12/MZ-12 transmitters it is needed to change the channel mapping in the Spirit Settings. Please go to the General tab/Channels and change Gyro Gain to Channel 7.
