Scorpion Telemetria
Revision as of 00:22, 2 September 2020 by PSzakra (Talk | contribs) (Created page with "ESC konfiguráció")
A Scorpion Tribunus ESC beépített telemetriás funkcióval rendelkezik a Programozási portban. Ez lehetővé teszi a telemetriai adatok továbbítását az egységbe.
1 ESC konfiguráció
To enable the ESC telemetry, it is necessary to set the Unsolicited telemetry mode in your ESC. With other modes the telemetry will not work. Change Communication protocol to Unsc Telem in the Scorpion Tribunus software. For this purpose Scorpion V link II Cable is needed.
2 Telemetry Cable
3 Interfacing
Servo connector of the Telem UNI cable should be connected to the ESC - programming port.
4.1 Telemetry activation
Go to the Advanced/Telemetry settings and set the Scorpion Tribunus option.
5 Displaying telemetry data
6 Supported models
Battery Voltage
Battery Current
BEC Voltage
Consumed Capacity
ESC Temperature
RPM
