Hyperion RPM érzékelő
Revision as of 10:50, 8 September 2020 by PSzakra (Talk | contribs) (Created page with "A Hyperion RPM érzékelő szabványos 1 vezetékes fordulatszám mérő")
Required modification
For usage with the Spirit units a small modification of the RPM cable is needed.
- Move the White cable to the middle in a new Servo connector/plug.
- You can do so with a needle easily.
- Wire layout
- White wire: RPM Output Signal (PIT pin)
- Red wire: BEC Voltage (AUX1/AUX2/CH0 or other power supply port)
- Black wire: Ground (AUX1/AUX2/CH0 or other power supply port)
