Governor
The governor from the Spirit unit (so called External governor) can be used with all single line digital receiver connections. This mean that for PWM and PPM it cannot be used. To make it work, you will need to get a RPM Sensor which can supply the unit with current RPM data.
1 Wiring
1.1 Throttle
For usage of this governor it is necessary to connect the throttle (ESC or the Throttle servo) to the following port:
- Spirit Pro and Spirit 2 - AUX1 port
- Spirit RS - THR port
1.2 RPM signal
To make the governor work well it is very important to choose an appropriate RPM sensor. RPM sensor can be external or built-in in the ESC.
Cable that carry RPM signal must be always connected when Governor is used.
Connect RPM signal cable to the pin of the unit:
- μSpirit - P pin - pin in the middle of P/E/A port
- Spirit Pro and Spirit 2 - PIT pin - pin in the middle of ELE/PIT/AIL port
- Spirit RS - RPM pin - pin in the middle of EXT/RPM/E2 port
Sensor can be powered from any available side Satellite port (SAT) or directly from a BEC. Side port is giving of 3.3V, while BEC is operating usually at 5 - 8V.
2 List of tested sensors
The following are known to work well.
- Electric Motors
- HobbyWing Platinum ESC v3/v4 RPM output
- YGE ESC RPM output
- CC Phoenix Edge RPM output
- Scorpion Commander V RPM output
- HobbyWing RPM Sensor
- Hyperion RPM Sensor
- Orange RPM Sensor
- Nitro and Gasser Motors
3 Wiring example
4 Setup
4.1 Electric
4.2 Nitro / Gasser
5 Activation
6 Spirit Settings
Fine-Tuning - Holding Limit
7 Transmitter
For a Combustion motors we recommend to go from Idle RPM (Throttle Curve around 10%) directly to 50% flat curve and above. This will trigger smooth spoolup.
8 Fine-Tuning Procedure
- Governor Response: 5
- Holding Performance: 1
9 Autorotation Bailout
10 Throttle Hold for Autorotation (optional)
11 Troubleshooting
- RPM signal was lost.
