Szabályzó / Governor
Governor from the Spirit unit (so called External governor) can be used with all single line digital receiver connections.
This mean that for PWM and PPM it cannot be used. To make it work, you will need to get a RPM Sensor which can supply the unit with current RPM data.
- 1 Wiring
- 2 A tesztelt érzékelők listája
- 3 Activation
- 4 Spirit Settings
- 9 Governor Setup Procedure
- 10 First start
- 11 Autó-rotáció Katapultálás
- 12 Gáz Tartás (Throttle Hold) Autó-rotáció-hoz (opció)
- 13 Probléma megoldás
1 Wiring
1.1 Throttle
For usage of the Spirit Governor it is necessary to connect the Throttle (ESC or the Throttle servo) to the following port:
- Spirit Pro and Spirit 2 - AUX1 port
- Spirit RS - THR port
1.2 RPM signal
To make the governor work well it is very important to choose an appropriate RPM sensor. RPM sensor can be external or built-in in the ESC.
Cable that carry RPM signal must be always connected when Governor is used.
Connect RPM signal cable to the pin of the unit:
- μSpirit - P pin - pin in the middle of P/E/A port
- Spirit Pro and Spirit 2 - PIT pin - pin in the middle of ELE/PIT/AIL port
- Spirit RS - RPM pin - pin in the middle of EXT/RPM/E2 port
Sensor can be powered from any available Satellite port (SAT) or directly from a BEC. Satellite port is giving 3.3V, while BEC is operating usually at 5 - 8V.
1.3 Wiring example
The following are known to work well.
- Elektromos motorok
- HobbyWing Platinum ESC v3/v4 RPM output/hu
- YGE ESC RPM output/hu
- CC Phoenix Edge RPM output/hu
- Scorpion Commander V RPM output/hu
- HobbyWing RPM Sensor/hu
- Hyperion RPM Sensor/hu
- Orange RPM Sensor/hu
3 Activation
First from all basic settings are necessary so the governor can control the head speed correctly. Please review all the parameters prior any configuration.
Fine-Tuning - Holding Limit
6.1 ESC Throttle Calibration
6.2 ESC setup
- Governor Response: 5
- Holding Performance: 1
10 First start
Azoknak a pilótáknak, akik autó-rotációt hajtanak végre, a Katapultálás (Bailout) funkció hasznos lehet. Ez a funkció lehetővé teszi a motor gyors felpörgetését a szükséges fordulatszámra. Az Autorotation Bailout értékét a Haladó/Szakértő beállítások( Advanced/Expert settings) -ben módosíthatja.
- Igényes manőverek után a fej fordulatszáma hosszabb ideig megtarthatja a magasabb értéket .
- Ellenőrizze, hogy az ESC vagy a Gáz-szervó megfelelően van-e konfigurálva a Gáz Tartományra. Általában a problémát a Gáz Tartomány (Throttle Range - Max). értékének túllépése okozza. Például, ha az ESC felső határa 1800μsec-ra van programozva, de az egység 1900μsec-ot konfigurált, akkor az egység 100μsec-al meghaladja a valós határt. Így nagy terhelés alatt néhány másodpercbe telhet, míg az érték ebben az esetben 1800μsec alá csökken.
- Helyes megoldás a Gáz Tartomány (Throttle Range) újra beállítása az ESC-ben vagy az egységben.
- A repülési naplóban gyakran szerepelRPM érzékelő adatai túl zajosak/RPM Sensor data are too noisy" esemény.
- Ellenőrizze, hogy az RPM érzékelő kimenete megfelelő-e. Ha az RPM érzékelő el van választva az ESC-től, kérjük, csatlakoztassa annak áramellátását (különösen a földelő vezetéket) a lehető legközelebb az egység RPM jelvezetékéhez. Ferritgyűrűk használata az áramellátáshoz csökkentheti a zajt is. Ellenőrizze az érzékelő üzemi feszültség követelményeit. Néhány érzékelő 3,5 V vagy annál nagyobb feszültséget igényel, így nem lehet őket táplálni az egység Spektrum portjáról. Bizonyos esetekben a szabályzó túl magas válaszértéke okozza, mert a motor elkezd rázkódni.
- A szabályzó nem vált a különböző gáz görbék között.
- Az ESC Gáz Tartománya hibásan van kalibrálva - az a tartomány, amelyre az egységben programozva, van, nem felel meg az ESC tartományának. A tartomány helyes kalibrálása megoldja a problémát.
- Az RPM jele elveszett.
- Ha a szabályzó elveszíti a jelet, 2 másodpercen belül észleli az eseményt. A szabályzó továbbra is dolgozni fog, de rosszabb a teljesítménnyel - hasonlóan a V-görbéhez. Ez az esemény akkor fordulhat elő, ha a jelkábel csatlakozása megszakad. Ezért javasoljuk, hogy forró ragasztóval vagy más módon rögzítse a csatlakozásokat.
