Szabályzó / Governor
Revision as of 13:17, 13 September 2020 by PSzakra (Talk | contribs) (Created page with "Gáz")
A Spirit egység szabályzója (ún. Külső szabályzó) minden egyvezetékes digitális vevőcsatlakozással használható.
Ez azt jelenti, hogy a PWM és a PPM kódolás esetén nem használható. Ahhoz, hogy működjön, szükség van egy fordulatszám-érzékelőre, amely képes ellátni az egységet az aktuális fordulatszám-adatokkal.
1 Bekötés
1.1 Gáz
For usage of the Spirit Governor it is necessary to connect the Throttle (ESC or the Throttle servo) to the following port:
  • Spirit and μSpirit - AUX port
  • Spirit Pro and Spirit 2 - AUX1 port
  • Spirit RS - THR port
1.2 RPM signal
To make the governor work well it is very important to choose an appropriate RPM sensor. RPM sensor can be external or built-in in the ESC.
Cable that carry RPM signal must be always connected when Governor is used.
Connect RPM signal cable to the pin of the unit:
  • μSpirit - P pin - pin in the middle of P/E/A port
  • Spirit - PIT pin - pin in the middle of ELE/PIT/AIL port
  • Spirit Pro and Spirit 2 - PIT pin - pin in the middle of ELE/PIT/AIL port
  • Spirit RS - RPM pin - pin in the middle of EXT/RPM/E2 port
Sensor can be powered from any available Satellite port (SAT) or directly from a BEC. Satellite port is giving 3.3V, while BEC is operating usually at 5 - 8V.
1.3 Wiring example
2 A tesztelt érzékelők listája
The following are known to work well.
Elektromos motorok
Nitrós és Gázturbinás Motorok
3 Activation
First from all basic settings are necessary so the governor can control the head speed correctly. Please review all the parameters prior any configuration.
Fine-Tuning - Holding Limit
5 Throttle Channel verification
6 Electric motors - ESC Setup
6.1 ESC Throttle Calibration
  1. Turn off Spirit Governor in order to perform Throttle Calibration.
  2. Set linear Throttle curve in your radio transmitter so that 0% and 100% throttle position matches with value of the Throttle bar in the Diagnostics tab. If it is not matching, use Subtrim function in your transmitter and/or Travel Adjustment function.
  3. Re-calibrate Throttle Range according the instructions of your ESC. In the most cases it can be configured by powering the model with throttle stick with 100% throttle and then by moving the stick down to 0%.
  4. Now you can enable Spirit Governor again.
6.2 ESC setup
7 Combustion motors - Throttle Servo Setup
9 Governor Setup Procedure
10 First start
11 Autó-rotáció Katapultálás
Azoknak a pilótáknak, akik autó-rotációt hajtanak végre, a Katapultálás (Bailout) funkció hasznos lehet. Ez a funkció lehetővé teszi a motor gyors felpörgetését a szükséges fordulatszámra. Az Autorotation Bailout értékét a Haladó/Szakértő beállítások( Advanced/Expert settings) -ben módosíthatja.
  • Autó-rotációkor ne kapcsolja be a Gáz Tartás (Throttle Hold) funkciót.
  • Használjon helyette egy hozzárendelt kapcsolót, amely a Gáz Görbét (Throttle Curve) 12 -50% közé állítja.
Info.png Ha a gáz görbe 12% alá csökken, akkor normális felpörgetési folyamat indul el.
12 Gáz Tartás (Throttle Hold) Autó-rotáció-hoz (opció)
  1. Állítsa a Gáz Görbét (Throttle Curve) a tartáskor (Hold) 12% -ra. (Ez felpörgeti a motort)
  2. Csökkentse az Általános/Govenor/Gáz Tartományt - Minimumra (General/Governor/Throttle Range - Min). - amíg a motor teljesen le nem áll.
  3. Növelje a Felpörgetési Gyorsaság (Spoolup Rampup) funkciót, amíg azonnali felpörgetést nem kap, amikor a Tartás (Hold) hatástalanítva van.
13 Probléma megoldás
  • Késés mutatkozik a Gáz Tartás (Throttle Hold) hatástalanítása és a motor forgása között - a motor rövid idő múlva kezd el forogni.
Győződjön meg arról, hogy a Gáz-tartomány megfelelően lett konfigurálva. Kalibrálta a gáz tartományt a Spirit kapcsolattal?
Javasoljuk, hogy az ESC-t állítsa a gyári beállításokra. A legtöbb esetben az alapértelmezett tartomány megfelel az egység előre konfigurált tartományának (1100μsec -1900μsec).
Abban az esetben, ha a tartomány megfelelően van beállítva, de még mindig észlelhető késés, kérjük, növelje a Spoolup Rampup paramétert, amíg a motor a Hold kapcsoló hatástalanítása után, azonnal elkezd forogni.
  • A motor a Hold kapcsoló hatástalanítása után rúgással indul, ami a modell nem kívánt forgását okozza.
Csökkentse a Spoolup Rampup paramétert, amíg a rúgás el nem tűnik. Ha késést észlel a felpörgés előtt, akkor az érték most túl alacsony, és más megoldást kell használni. Ebben az esetben a problémát a Spirit egység egyetlen beállításával sem lehet megoldani.
Ellenőrizze, hogy az ESC támogatja-e a Spoolup Power paramétert. Ha támogatott, akkor próbálja csökkenteni a teljesítményt, és figyelje meg, hogy segít-e Önnek. Bizonyos esetekben más időzítés vagy PWM frekvencia segíthet, de mindig győződjön meg arról, hogy a beállítások érvényesek-e a motorjára.
  • Igényes manőverek után a fej fordulatszáma hosszabb ideig megtarthatja a magasabb értéket .
Ellenőrizze, hogy az ESC vagy a Gáz-szervó megfelelően van-e konfigurálva a Gáz Tartományra. Általában a problémát a Gáz Tartomány (Throttle Range - Max). értékének túllépése okozza. Például, ha az ESC felső határa 1800μsec-ra van programozva, de az egység 1900μsec-ot konfigurált, akkor az egység 100μsec-al meghaladja a valós határt. Így nagy terhelés alatt néhány másodpercbe telhet, míg az érték ebben az esetben 1800μsec alá csökken.
Helyes megoldás a Gáz Tartomány (Throttle Range) újra beállítása az ESC-ben vagy az egységben.
  • A repülési naplóban gyakran szerepelRPM érzékelő adatai túl zajosak/RPM Sensor data are too noisy" esemény.
Ellenőrizze, hogy az RPM érzékelő kimenete megfelelő-e. Ha az RPM érzékelő el van választva az ESC-től, kérjük, csatlakoztassa annak áramellátását (különösen a földelő vezetéket) a lehető legközelebb az egység RPM jelvezetékéhez. Ferritgyűrűk használata az áramellátáshoz csökkentheti a zajt is. Ellenőrizze az érzékelő üzemi feszültség követelményeit. Néhány érzékelő 3,5 V vagy annál nagyobb feszültséget igényel, így nem lehet őket táplálni az egység Spektrum portjáról. Bizonyos esetekben a szabályzó túl magas válaszértéke okozza, mert a motor elkezd rázkódni.
  • A szabályzó nem vált a különböző gáz görbék között.
Az ESC Gáz Tartománya hibásan van kalibrálva - az a tartomány, amelyre az egységben programozva, van, nem felel meg az ESC tartományának. A tartomány helyes kalibrálása megoldja a problémát.
  • Az RPM jele elveszett.
Ha a szabályzó elveszíti a jelet, 2 másodpercen belül észleli az eseményt. A szabályzó továbbra is dolgozni fog, de rosszabb a teljesítménnyel - hasonlóan a V-görbéhez. Ez az esemény akkor fordulhat elő, ha a jelkábel csatlakozása megszakad. Ezért javasoljuk, hogy forró ragasztóval vagy más módon rögzítse a csatlakozásokat.
