Seguridad SpiritRS
Los modelos R/C tales como los helicópteros no son juguetes! Es necesario verificar las instrucciones del modelo, cumplir con las normas locales y realizar inspecciones pre-vuelo del modelo para así poder detectar fallos mecánicos, eléctricos u otros fallos inmediatamente antes de ponerlo en vuelo.
Las palas del rotor y las hélices giran a alta velocidad y pueden causar graves daños a las personas y bienes físicos si no se manejan con cuidado.
If you encounter any problems, contact your dealer or other experienced modelers.
Pay particular attention to your own safety and the safety of others. Never fly amongst or over people, animals, or on private property without prior authorization from the property owner. Fly only in safe places where no additional damage is possible to other objects, because the model can suddenly become unmanageable for various reasons, such as failure of electronics, mechanical failure, pilot error or radio interference.
Do not try to fly damaged models or perform repairs using damaged parts; always replace damaged parts with new ones. Never fly a model which exhibits excess vibrations, this may cause unwanted flight characteristics or in-flight failures. Find the source of the vibrations and fix the problem.
Spirit RS is not an autopilot, it is necessary to have knowledge of flying R/C models. The system is only designed to improve flight experience. We recommend using R/C simulators designed for training before the first flight.
The user takes full responsibility for any damage or injury caused while flying an R/C model equipped with one of our devices. The manufacturer can neither guarantee nor control the conditions in which the unit is being used.
