Telemetría de Variador
Revision as of 18:31, 17 October 2020 by Luisgarag (Talk | contribs) (Created page with "La telemetría de variador le permite visualizar los datos de su variador directamente en su emisora. Dependiendo de las capacidades de su emisora, podrá además guardar dich...")
La telemetría de variador le permite visualizar los datos de su variador directamente en su emisora. Dependiendo de las capacidades de su emisora, podrá además guardar dichos datos y utilizarlos a posteriori para varios fines.
The ESC telemetry is mediated through the Spirit units (firmware v2.4+) as these are able to read the data and communicate with both receiver and ESC at the same time.
1 List of supported Radios
Info.png These radios support full integration/telemetry as well.
2 List of supported ESCs
3 Interfacing
4 Telemetry data
  • Battery Voltage [V]
  • Battery Current [A]
  • Head Speed [RPM] - provided by RPM sensor or ESC. (also with ESC Telemetry disabled)
