Problemas y soluciones
Revision as of 12:02, 19 September 2016 by Spiritdm (Talk | contribs) (Created page with "Disminuya ganancia de cola en emisora")
| Descipcion de problema | Solucion |
| Derivas en Plato cíclico o cola después de la inicialización | Compruebe trim ysubtrims. Sticks en posición de punto muerto debe ser 0%, consulte la ficha Diagnóstico. Aumentar banda muerta del palillo en la pestaña Avanzado. |
| Cola y ciclico no es preciso. | Aumentar la ganancia cíclica y/o aumentar la ganancia del giróscopo en el transmisor. Añadir exponencial en el transmisor. |
| Movimiento de paso cíclico agresivo o huida de avance rápido conduce a rápidos, grandes oscilaciones de la cola | Disminuir la consistencia pirueta en la ficha Opciones avanzadas gradualmente por 10 hasta que este desaparece. Compruebe la mecánica de la cola para la unión. |
| Oscila Modelo en elevador o alerones ejes | Disminuya ganacia ciclico en Sensor tab. |
| Cola oscila rápidamente | Disminuya ganancia de cola en emisora |
| Model pirouette rotation is too slow/fast | Increase/decrease rotation speed for rudder in Sensor tab. |
| Servos jitter randomly without external influences | Check the cable connection between the receiver and the unit. |
| During stationary pirouettes model drifts | Check the Subtrim configuration in the Servos tab. It seems to be inprecise. |
| Aggressive elevator stick movement leads to bouncing | Increase elevator filter in Advanced tab and/or decrease cyclic feed forward in Advanced tab. |
| Cyclic feel is delayed or disconnected | Increase cyclic feed forward in Advanced tab. |
| Elevator servo is not moving when initialization is finished | Flight log from the previous flight was saved. View the log in the Diagnostic tab and fix reported problem. |
| Swashplate is jumping in a cycle when initialization is finished | The unit was started with the Rescue mode engaged. Turn off the rescue from your transmitter. |
| Rudder stop is not equal for both sides | Check rudder servo center position, rudder mechanics. You can also try to lower rudder limit for the side where bounce-back occur. |
