Translations:Configuration/195/it
Revision as of 09:40, 13 January 2021 by DaniloB (Talk | contribs) (Created page with "'''Rudder Gain''' – This parameter is enabled only in case of unassigned Gyro Gain channel. It replaces function of Gyro Gain from the transmitter, so you can directly set t...")
