Scorpion Telemetria
Revision as of 16:14, 13 January 2021 by DaniloB (Talk | contribs) (Created page with "Modificare '''Protocollo di comunicazione''' in '''Unsc Telem''' nel [http://www.scorpionsystem.com/files/download/Scorpions_Heli_ESC_1.02_log.msi software Scorpion Tribunus].")
1 ESC configurazione
Per abilitare la telemetria ESC, è necessario impostare la modalità telemetria Unsolicitednell'ESC. Con altre modalità la telemetria non funzionerà. Modificare Protocollo di comunicazione in Unsc Telem nel software Scorpion Tribunus. For this purpose Scorpion V link II Cable is needed.
2 Telemetry Cable
3 Interfacing
Servo connector of the Telem UNI cable should be connected to the ESC - programming port.
4.1 Telemetry activation
Go to the Advanced/Telemetry settings and set the Scorpion Tribunus option.
5 Displaying telemetry data
6 Supported models
Battery Voltage
Battery Current
BEC Voltage
Consumed Capacity
ESC Temperature
RPM
