Governo
Il governatore dell'unità Spirit (il cosiddetto governatore esterno) può essere utilizzato con tutte le connessioni del ricevitore digitale a linea singola.
Ciò significa che per PWM e PPM non può essere utilizzato. Per farlo funzionare, è necessario disporre di un sensore RPM che possa fornire all'unità i dati RPM correnti.
- 1 cablaggio
- 2 List of tested sensors
- 3 Activation
- 4 Spirit Settings
- 9 Governor Setup Procedure
- 10 First start
- 11 Autorotation Bailout
- 12 Throttle Hold for Autorotation (optional)
- 13 Troubleshooting
1 cablaggio
1.1 Acceleratore (gas)
For usage of the Spirit Governor it is necessary to connect the Throttle (ESC or the Throttle servo) to the following port:
- Spirit Pro and Spirit 2 - AUX1 port
- Spirit RS - THR port
1.2 RPM signal
To make the governor work well it is very important to choose an appropriate RPM sensor. RPM sensor can be external or built-in in the ESC.
Cable that carry RPM signal must be always connected when Governor is used.
Connect RPM signal cable to the pin of the unit:
- μSpirit - P pin - pin in the middle of P/E/A port
- Spirit Pro and Spirit 2 - PIT pin - pin in the middle of ELE/PIT/AIL port
- Spirit RS - RPM pin - pin in the middle of EXT/RPM/E2 port
Sensor can be powered from any available Satellite port (SAT) or directly from a BEC. Satellite port is giving 3.3V, while BEC is operating usually at 5 - 8V.
1.3 Wiring example
The following are known to work well.
- Electric Motors
- HobbyWing Platinum ESC v3/v4 RPM output
- YGE ESC RPM output
- CC Phoenix Edge RPM output
- Scorpion Commander V RPM output
- HobbyWing RPM Sensor
- Hyperion RPM Sensor
- Orange RPM Sensor
- Nitro and Gasser Motors
3 Activation
First from all basic settings are necessary so the governor can control the head speed correctly. Please review all the parameters prior any configuration.
Fine-Tuning - Holding Limit
6.1 ESC Throttle Calibration
6.2 ESC setup
- Governor Response: 5
- Holding Performance: 1
10 First start
13 Troubleshooting
- RPM signal was lost.
