HobbyWing Platinum ESC v3/v4 RPM
Revision as of 12:11, 14 January 2021 by DaniloB (Talk | contribs) (Created page with "Modifica richiesta")
Gli ESC HobbyWing v3 / v4 sono dotati di un cavo RPM che fornisce il segnale al regolatore esterno. Quindi non è necessario fare altro se non collegare correttamente i cavi e spegnere il Governo interno dell'ESC.
1 Modifica richiesta
For usage with the Spirit units a small modification of the RPM cable is needed.
- Move the Yellow cable to the middle in the Servo connector.
- You can do so with a needle easily.
- Wire layout
- Yellow wire: RPM Output Signal (PIT pin)
- White wire: Throttle signal (AUX1 port)
- Red wire: BEC Voltage (AUX1 port)
- Black wire: Ground (AUX1 port)
2 Changing ESC mode
It is very important to change ESC mode so that internal Governor is disabled.
This can be made by a Multifunction LCD Program Box. Please see HobbyWing manual.
You can use the following modes:
- Helicopter (Linear Throttle) - great for beginners.
- Fixed-wing - great for advanced (will eliminate problems with slow spoolup and Autorotation Bailout feature).
3 Governor Settings
- Throttle Frequency: 120Hz.
- Throttle Range - Min.: 1100 us.
