Hyperion RPM Sensore
Revision as of 11:57, 14 January 2021 by DaniloB (Talk | contribs) (Created page with "Modifica richiesta")
Il sensore RPM Hyperion è un'unità standard per misurare RPM da un filo di fase.
Modifica richiesta
For usage with the Spirit units a small modification of the RPM cable is needed.
  • Move the White cable to the middle in a new Servo connector/plug.
  • You can do so with a needle easily.
Wire layout
White wire: RPM Output Signal (PIT pin)
Red wire: BEC Voltage (AUX1/AUX2/CH0 or other power supply port)
Black wire: Ground (AUX1/AUX2/CH0 or other power supply port)
