Modalità Stabi
Revision as of 18:18, 14 January 2021 by DaniloB (Talk | contribs) (Created page with "Guadagno giroscopico negativo")
Per abilitare le modalità di salvataggio o stabilizzazione è necessario impostare "Stabi / Funzione" sull'opzione desiderata. Quando è "Disabilitato", non verrà utilizzata alcuna funzione speciale.
Info.png È possibile impostare diverse funzioni tra i Banchi.
Dalla versione 2.3.0 è possibile attivare lo Stabi / Funzione nei due modi:
  • Negative Gyro Gain
  • Separate channel (NEW)
1 Guadagno giroscopico negativo
Info.png Gyro Gain is still used to set the rudder gyro gain. At the same time, positive or negative value will determine if selected function is inactive or active. So it is important to set the gyro gain properly for both normal flight and selected function. Usually same, but opposite values are fine (for example +60%/-60%)
  • Position 0: 50% (normal flight)
  • Position 1: -50% (selected function)
1.2 In the software
1. First step
2.Second step
1.3 Function vs Gyro
Function Gyro Gain Gyro Mode Flight Mode
Disabled 0 - 100% Head-Lock -
Stabilisation (Scale) 0 - 100% Head-Lock -
Coaxial 0 - 100% Head-Lock -
2 Separate channel
Channel configuration
  1. Open the General/Channels.
Function indicator
  • 0 - function is inactive.
  • 1 - function is active.
Info.png Gyro Gain can still change gyro mode (Head-Lock or Normal). Positive Gyro Gain value will activate Head-Lock mode always. Active Function and Gyro mode is always visible in the Diagnostic tab.
2.1 Function vs Channel
  • Flight Mode "-" mean that the function is inactive and a normal flight regime is on.
Function Channel Gyro Mode Flight Mode
Disabled -100% - 0% Head-Lock / Normal -
Rescue (Normal) -100% - 0% Head-Lock -
Rescue (Acro) -100% - 0% Head-Lock -
Stabilisation (Normal) -100% - 0% Head-Lock -
Stabilisation (Acro) -100% - 0% Head-Lock -
Stabilisation (Scale) -100% - 0% Head-Lock / Normal -
Coaxial -100% - 0% Head-Lock -
Disabled 0 - 100% Head-Lock / Normal -
Rescue (Normal) 0 - 100% Head-Lock Rescue
Rescue (Acro) 0 - 100% Head-Lock Rescue
Stabilisation (Normal) 0 - 100% Head-Lock Stabilisation
Stabilisation (Acro) 0 - 100% Head-Lock Stabilisation
Stabilisation (Scale) 0 - 100% Head-Lock / Normal Stabilisation
Coaxial 0 - 100% Head-Lock Stabilisation
