Funzionalità GeoLink
Revision as of 18:16, 15 January 2021 by DaniloB (Talk | contribs) (Created page with "Come funziona")
1 Acceleratore TTFF
1.1 Come funziona
When module is powered up for the first time at a given day it is trying to find a satellites. It will do so in a normal way (without any time reduction). With GeoLink this should be between 20 - 35 seconds normally (depending on conditions).
Right after the flight and next power up this period is reduced significantly. When powering up within few minutes to hours you can always notice the time required for Fix is shortened.
1.2 How can it help me?
2 Logging
2.1 Logging specification
  • Up to 1.5 hour
  • Up to 63 logged flights
  • Recording period: 1 second
2.2 What is being logged?
  • Position on Earth: Latitude and Longitude
  • Altitude: relative altitude from starting point
  • Speed: flying speed of the model
  • Heading: direction in which model is flying
  • Date and time
2.3 Log viewer
2.4 Log backup and sharing
3 Return To Home
  • in the Spirit Settings by choosing the best spot at the map
  • by transmitter command being at the place considered as a new Home.
3.1 Description
3.2 With Altitude Hold
4 Auto Landing
4.1 Description
5 Position Hold
5.1 Description
5.2 With Altitude Hold
6 Geo-fence
6.1 Description
6.2 With Altitude Hold
7 Altitude Hold
7.1 Description
8 Altitude Limit
8.1 Description
