Funzionalità GeoLink
1 Acceleratore TTFF
1.1 Come funziona
Quando il modulo viene acceso per la prima volta in un dato giorno, sta cercando di trovare un satellite. Lo farà in modo normale (senza alcuna riduzione di tempo). Con GeoLink questo dovrebbe normalmente essere compreso tra 20 e 35 secondi (a seconda delle condizioni).
Right after the flight and next power up this period is reduced significantly. When powering up within few minutes to hours you can always notice the time required for Fix is shortened.
1.2 How can it help me?
2 Logging
2.1 Logging specification
- Up to 1.5 hour
- Up to 63 logged flights
- Recording period: 1 second
2.2 What is being logged?
- Position on Earth: Latitude and Longitude
- Altitude: relative altitude from starting point
- Speed: flying speed of the model
- Heading: direction in which model is flying
- Date and time
2.3 Log viewer
2.4 Log backup and sharing
3 Return To Home
- in the Spirit Settings by choosing the best spot at the map
- by transmitter command being at the place considered as a new Home.
3.1 Description
3.2 With Altitude Hold
4 Auto Landing
4.1 Description
5 Position Hold
5.1 Description
5.2 With Altitude Hold
6 Geo-fence
6.1 Description
6.2 With Altitude Hold
7 Altitude Hold
7.1 Description
8 Altitude Limit
8.1 Description
Altitude is determined from initialization point. This mean that at initialization altitude the model is at zero.
