Risoluzione dei problemi di GeoLink
Revision as of 19:16, 15 January 2021 by DaniloB (Talk | contribs) (Created page with "1x lampeggio")
In caso di problemi, GeoLink avviserà il pilota tramite il LED di stato integrato. Qualsiasi guasto è segnalato dal lampeggiamento del LED di stato che si ripete periodicamente. Se si verifica un problema dopo un arresto anomalo, è necessaria la riparazione di GeoLink.
Il LED lampeggiante potrebbe apparire immediatamente dopo l'accensione. In base al numero di lampeggi del LED in serie è possibile determinare quale problema è presente.
1 Avvisi Fallimenti
1.1 1x lampeggio
Stored hardware data in GeoLink were lost. Contacting Spirit System support is necessary.
1.2 2x blink
Pressure sensor is not operating correctly. Usually this problem occur when GeoLink is operated for prolonged time under extremely high humidity conditions. Store GeoLink in low humidity environment for few hours until internal condensate will evaporate. If this will not help contact Spirit System support.
1.3 3x blink
Gyro, accelerometer sensors are not operating correctly. Contacting Spirit System support is necessary.
1.4 4x blink
Compass sensor is not operating correctly. Contacting Spirit System support is necessary.
1.5 Constant blinking
This might happen rather in-flight and could signalize unexpected failure. Most probable reason is shock by high electrostatic discharge. This will result in the GeoLink connection is broken event and loss of GeoLink functionality from the moment it will occur.
2 Other notifications
2.1 Calibration process
If you can see 3 series of fast flashing (followed by fast erratic blinks) after power up of the GeoLink then the module is in so called Calibration process. This process can be invoked by pilot through the Spirit Settings software and must be finished according instructions. Until finished the GeoLink will be inoperable. Spirit Settings will display Not connected message until the calibration is finished.
