Risoluzione dei problemi di GeoLink
Revision as of 20:19, 15 January 2021 by DaniloB (Talk | contribs) (Created page with "Precisione")
1 Precisione
If you are encountering precision problem of a GeoLink feature, please read the following sections.
1.1 Drifting
If model is drifting after engaging Position Hold, Return to Home or GeoFence feature it is required to make sure that:
  • GeoLink Compass Calibration is performed correctly.
  • Stabilisation mode such as Stabilisation (Normal), Stabilisation (Acro), Coaxial is not drifting even after prolonged flight time.
1.1.1 Incorrect Compass Calibration
Incorrect Calibration can be distinguished with GeoLink Position Hold in the easiest way. We recommend to engage the feature in a safe altitude and then observe behavior of the model.
If model will start to make a circles then Compass Calibration is wrong. If even Calibration at the flying field will not help, the problem can be alternatively fixed by adjusting Compass Heading Correction parameter.
1.1.2 Stabilisation drift
Please make sure that Stabilisation is working precisely prior usage of a GeoLink features. This is very important as GeoLink is based on the Stabilisation feature. We recommend to set Coaxial mode while GeoLink support can be disabled for testing.
For GeoLink features to operate the most precisely Stabi Correction ON is the best option. Please note it is not possible to utilize this feature with all models - see the page above.
2 Avvisi Fallimenti
In caso di problemi, GeoLink avviserà il pilota tramite il LED di stato integrato. Qualsiasi guasto è segnalato dal lampeggiamento del LED di stato che si ripete periodicamente. Se si verifica un problema dopo un arresto anomalo, è necessaria la riparazione di GeoLink.
Il LED lampeggiante potrebbe apparire immediatamente dopo l'accensione. In base al numero di lampeggi del LED in serie è possibile determinare quale problema è presente.
2.1 1x lampeggio
Dati hardware memorizzati in GeoLink sono andati persi. È necessario contattare l'assistenza di Spirit System.
2.2 2x lampeggio
Il sensore di pressione non funziona correttamente. Di solito questo problema si verifica quando GeoLink viene utilizzato per un periodo prolungato in condizioni di umidità estremamente elevata. Conservare GeoLink in un ambiente a bassa umidità per alcune ore finché la condensa interna non evapora. Se questo non aiuta, contatta il supporto di Spirit System.
2.3 3x lampeggio
Il giroscopio, i sensori dell'accelerometro non funzionano correttamente. È necessario contattare l'assistenza di Spirit System.
2.4 4x lampeggio
Il sensore della bussola non funziona correttamente. È necessario contattare l'assistenza di Spirit System.
2.5 Lampeggio costante
Ciò potrebbe accadere piuttosto in volo e potrebbe segnalare un guasto imprevisto. La ragione più probabile è lo shock causato da un'elevata scarica elettrostatica. Ciò comporterà il evento di connessione GeoLink interrotta e la perdita della funzionalità GeoLink dal momento in cui si verificherà.
3 Altre notifiche
Nel caso in cui GeoLink lampeggi e il pilota non possa accedervi tramite le impostazioni dello spirit, il motivo può essere il seguente.
3.1 Processo di calibrazione
Se si possono vedere 3 serie di lampeggi veloci (seguiti da lampeggi veloci e irregolari) dopo l'accensione del GeoLink, il modulo è nel cosiddetto processo di calibrazione. Questo processo può essere richiamato dal pilota tramite il software Spirit Settings e deve essere completato secondo le funzioni GeoLink. Fino al termine, GeoLink sarà inutilizzabile. Spirit Settings visualizzerà il messaggio Not connected fino al termine della calibrazione.
