Modalità normale
Revision as of 09:27, 16 January 2021 by DaniloB (Talk | contribs) (Created page with "Alla deriva (Drifting)")
La modalità normale è la funzione del giroscopio del timone in cui compensa un movimento nell'asse di imbardata. Questa modalità è spesso chiamata Modalità tasso . A differenza della modalità Head-Lock, la modalità Normale non mantiene esattamente la posizione di imbardata. Ciò significa che il timone può essere una deriva.
1 Alla deriva (Drifting)
When hovering, drifting should not occur if the rudder mechanics has correctly configured neutral position. But in case of a wind, the drift can occur. This mode is suitable only for forward flight.
2 Activation
To activate this mode set the Gyro Gain to a negative value. To be sure that the mode is active, open the Diagnostic tab. Gyro Bar should display Normal when Normal mode is active. This mode can work only when Stabi/Function parameter is set to Disabled.
3 Usage
If you want to set the rudder mechanic precisely, we recommend to use this mode. Simply activate the mode during hovering and observe if there is any drift. If there is a drift, then it mean that the rudder neutral position is not configured well. Try to change push rod length of the rudder control mechanics to compensate this drift. This configuration can greatly improve performance of the rudder including stopping behavior.
