Geolink Montage
Revision as of 12:35, 18 March 2021 by WilhelmL (Talk | contribs) (Created page with "Montage am Helikopter")
Die korrekte Montage ist das Wichtigste, um optimalen Betriebsbedingungen zu erreichen. Bei unsachgemäßer Montage kann das GeoLink nicht mit hoher Genauigkeit arbeiten oder im schlimmsten Fall können sogar einige Funktionen nicht genutzt werden.
Bitte achten sie besonders darauf, die folgenden Schritte gründlichst zu befolgen.
1 Montage am Helikopter
  • Horizontal (0°) - connector is pointing to main rotor
  • Horizontal (180°) - connector is pointing to tail rotor
1.1 Where to mount
  • It has clear sky visibility
  • It is perfectly horizontally aligned
Choose a position which is not too far, so that provided cable is long enough. Placing module too far on the boom could lead to bad Center of Gravity of the model.
1.2 How to mount
Warning.png Never mount GeoLink directly on a thick metallic parts, near a motor or any servo.
Warning.png Do not cover GeoLink connector with any tape, glue or paint. Opening above the connector is used to determine ambient pressure and altitude.
1.4 Unmounting
1.5 Mounting examples
1.5.1 LYNX Oxy 2
LYNX Oxy 2
1.5.2 KDS Chase 360
KDS Chase 360
KDS Chase 360
KDS Chase 360
1.5.3 SAB Goblin 700
SAB Goblin 700
SAB Goblin 700
2 Wiring
Wiring with Spirit Pro unit.
3 Alignment
3.1 Alignment procedure
  2. Power up the Spirit unit.
