GeoLink Hibajelzések
Revision as of 13:28, 28 March 2021 by PSzakra (Talk | contribs) (Created page with "Pontosság")
1 Pontosság
If you are encountering precision problem of a GeoLink feature, please read the following sections.
1.1 Drifting
If model is drifting after engaging Position Hold, Return to Home or GeoFence feature it is required to make sure that:
  • GeoLink Compass Calibration is performed correctly.
  • Stabilisation mode such as Stabilisation (Normal), Stabilisation (Acro), Coaxial is not drifting even after prolonged flight time.
1.1.1 Incorrect Compass Calibration
Incorrect Calibration can be distinguished with GeoLink Position Hold in the easiest way. We recommend to engage the feature in a safe altitude and then observe behavior of the model.
If model will start to make a circles then Compass Calibration is wrong. If even Calibration at the flying field will not help, the problem can be alternatively fixed by adjusting Compass Heading Correction parameter.
1.1.2 Stabilisation drift
Please make sure that Stabilisation is working precisely prior usage of a GeoLink features. This is very important as GeoLink is based on the Stabilisation feature. We recommend to set Coaxial mode while GeoLink support can be disabled for testing.
For GeoLink features to operate the most precisely Stabi Correction ON is the best option. Please note it is not possible to utilize this feature with all models - see the page above.
2 Hiba jelzések
Probléma esetén a GeoLink a LED villogásával értesíti a pilótát. A LED ismétlődő villogása minden hibát kijelez. Törések után a GeoLink javítását is el kell végezni, ha szükséges.
A LED villogása a bekapcsolás után azonnal megjelenhet. A felvillanások száma mutatja meg a fennálló problémát.
2.1 1 x felvillanás
A GeoLink tárolt hardver adatai elvesztek. Lépjen kapcsolatba a Spirit System gyártójával.
2.2 2 x felvillanás
A nyomásérzékelő nem működik megfelelően. Általában ez a probléma akkor jelentkezik, ha a GeoLink-et hosszabb ideig üzemeltetik rendkívül magas páratartalom mellett. Néhány órán keresztül tárolja a GeoLink-et alacsony páratartalmú környezetben, amíg a belső kondenzátum elpárolog. Ha ez nem segít, lépjen kapcsolatba a Spirit System gyártójával.
2.3 3 x felvillanás
Gyro, vagy/és a gyorsulásmérő szenzorok nem működnek megfelelően. Lépjen kapcsolatba a Spirit System gyártójával.
2.4 4 x felvillanás
Iránytű-érzékelő nem működik megfelelően. Lépjen kapcsolatba a Spirit System gyártójával.
2.5 Folyamatos felvillanások
Ez valószínűleg repülés közben fordulhat elő, és jelezheti a váratlan hibát. A legvalószínűbb ok, a nagy elektrosztatikus kisülés által okozott sokk. Ennek eredményeként a GeoLink kapcsolat megszakad, és a GeoLink támogatási funkciói elvesznek attól a pillanattól kezdve, amikor ez megtörténik
3 Egyéb értesítések
Abban az esetben, ha a GeoLink villog, és a pilóta nem tudja elérni azt a Spirit Settings segítségével, ezt az okozhatja, hogy:
3.1 Kalibrációs folyamat
Ha a GeoLink bekapcsolása után 3 gyors villogás sorozatot lát (gyorsan villogó villogást követ), akkor a modul az úgynevezett Kalibrációs folyamatban van. Ezt a folyamatot a pilóta meghívhatja a Spirit Settings szoftver segítségével, és azt az utasításoknak megfelelően kell befejezni. [leírás]. A GeoLink ennek befejezéséig nem lesz működőképes. A Spirit Settings-ben a Nem Csatlakoztatott/Not Connected felirat, marad, amíg a kalibrálás be nem fejeződik!
