GeoLink Troubleshooting
Revision as of 12:44, 29 April 2021 by Admin (Talk | contribs)
1 Precision
If you are encountering precision problem of a GeoLink feature, please read the following sections.
1.1 Drifting
If model is drifting after engaging Position Hold, Return to Home or GeoFence feature it is required to make sure that:
  • GeoLink Compass Calibration is performed correctly.
  • Stabilisation mode such as Stabilisation (Normal), Stabilisation (Acro), Coaxial is not drifting even after prolonged flight time.
1.1.1 Incorrect Compass Calibration
Incorrect Calibration can be distinguished with GeoLink Position Hold in the easiest way. We recommend to engage the feature in a safe altitude and then observe behavior of the model.
If model will start to make a circles then Compass Calibration is wrong. If even Calibration at the flying field will not help, the problem can be alternatively fixed by adjusting Compass Heading Correction parameter.
1.1.2 Stabilisation drift
Please make sure that Stabilisation is working precisely prior usage of a GeoLink features. This is very important as GeoLink is based on the Stabilisation feature. We recommend to set Coaxial mode while GeoLink support can be disabled for testing.
For GeoLink features to operate the most precisely Stabi Correction ON is the best option. Please note it is not possible to utilize this feature with all models - see the page above.
2 Failures
In case of a problem GeoLink will notify pilot by built-in Status LED. Any failure is signalized by flashing Status LED that is repeating periodically. If some issue occured after a crash then repair of the GeoLink is required.
LED flashing may show up immediately after power up. By number of LED blinks in series you can determine which problem is present.
2.1 1x blink
Stored hardware data in GeoLink were lost. Contacting Spirit System support is necessary.
2.2 2x blink
Pressure sensor is not operating correctly. Usually this problem occur when GeoLink is operated for prolonged time under extremely high humidity conditions. Store GeoLink in low humidity environment for few hours until internal condensate will evaporate. If this will not help contact Spirit System support.
2.3 3x blink
Gyro, accelerometer sensors are not operating correctly. Contacting Spirit System support is necessary.
2.4 4x blink
Compass sensor is not operating correctly. Contacting Spirit System support is necessary.
2.5 Constant blinking
This might happen rather in-flight and could signalize unexpected failure. Most probable reason is shock by high electrostatic discharge. This will result in the GeoLink connection is broken event and loss of GeoLink functionality from the moment it will occur.
3 Other notifications
3.1 Calibration process
If you can see 3 series of fast flashing (followed by fast erratic blinks) after power up of the GeoLink then the module is in so called Calibration process. This process can be invoked by pilot through the Spirit Settings software and must be finished according instructions. Until finished the GeoLink will be inoperable. Spirit Settings will display Not connected message until the calibration is finished.
