Řešení problémů
Revision as of 08:04, 15 September 2021 by FuzzyBot (Talk | contribs) (Updating to match new version of source page)
1 Precision
If you are encountering precision problem of a GeoLink feature, please read the following sections.
1.1 Drifting
If model is drifting after engaging Position Hold, Return to Home or GeoFence feature it is required to make sure that:
  • GeoLink Compass Calibration is performed correctly.
  • Stabilisation mode such as Stabilisation (Normal), Stabilisation (Acro), Coaxial is not drifting even after prolonged flight time.
1.1.1 Incorrect Compass Calibration
Incorrect Calibration can be distinguished with GeoLink Position Hold in the easiest way. We recommend to engage the feature in a safe altitude and then observe behavior of the model.
If model will start to make a circles then Compass Calibration is wrong. If even Calibration at the flying field will not help, the problem can be alternatively fixed by adjusting Compass Heading Correction parameter.
1.1.2 Stabilisation drift
Please make sure that Stabilisation is working precisely prior usage of a GeoLink features. This is very important as GeoLink is based on the Stabilisation feature. We recommend to set Coaxial mode while GeoLink support can be disabled for testing.
For GeoLink features to operate the most precisely Stabi Correction ON is the best option. Please note it is not possible to utilize this feature with all models - see the page above.
2 Poruchy
V případě, že se vyskytne porucha modulu, je pilot informován stavovou LED. Jakýkoli chybový stav je signalizován periodickým blikáním stavové LED. Pokud se objeví chyba např. po havárii modelu, pak je nezbytná jeho oprava.
Blikání stavové LED se v případě poruchy objeví ihned po připojení napájení. Počtem probliknutí ihned za sebou lze určit o jakou chybu se jedná.
2.1 1x bliknutí
Uložené data o hardware modulu byla ztracena. Je nezbytné kontaktovat výrobce.
2.2 2x bliknutí
Tlakový senzor nefunguje správně. Tento problém se může projevit, byl-li modul vystavován po delší dobu velmi vysoké vlhkosti. Umístěte GeoLink do prostředí s velmi nízkou vlhkostí alespoň na několik hodin, dokud se konenzát uvnitř neodpaří. Pokud se problém nepodaří odstranit, kontaktujte výrobce.
2.3 3x bliknutí
Gyro nebo akcelerometr nefungují správně. Je nezbytné kontaktovat výrobce.
2.4 4x bliknutí
Kompas nefunguje správně. Je nezbytné kontaktovat výrobce.
2.5 Konstantní blikání
3 Jiná hlášení
V případě, že modul GeoLink bliká a nekomunikuje s programem Spirit Settiongs, pak se může jednat o následující případ.
3.1 Kalibrace kompasu
If you can see 3 series of fast flashing (followed by fast erratic blinks) after power up of the GeoLink then the module is in so called Calibration process. This process can be invoked by pilot through the Spirit Settings software and must be finished according instructions. Until finished the GeoLink will be inoperable. Spirit Settings will display Not connected message until the calibration is finished.
