Governor
Revision as of 07:04, 30 September 2021 by FuzzyBot (Talk | contribs) (Updating to match new version of source page)
Governor from the Spirit unit (so called External governor) can be used with all single line digital receiver connections.
This mean that for PWM and PPM it cannot be used. To make it work, you will need to get a RPM Sensor which can supply the unit with current RPM data.
1 Wiring
1.1 Throttle
For usage of the Spirit Governor it is necessary to connect the Throttle (ESC or the Throttle servo) to the following port:
  • Spirit and μSpirit - AUX port
  • Spirit Pro and Spirit 2 - AUX1 port
  • Spirit RS and Spirit GTR - THR port
1.2 RPM signal
To make the governor work well it is very important to choose an appropriate RPM sensor. RPM sensor can be external or built-in in the ESC.
Cable that carry RPM signal must be always connected when Governor is used.
Connect RPM signal cable to the pin of the unit:
  • μSpirit - P pin - upper pin of the P/E/A port
  • Spirit - PIT pin - pin in the middle of ELE/PIT/AIL port
  • Spirit Pro and Spirit 2 - PIT pin - pin in the middle of ELE/PIT/AIL port
  • Spirit RS and Spirit GTR - RPM pin - pin in the middle of EXT/RPM/E2 port
Sensor can be powered from any available Satellite port (SAT) or directly from a BEC. Satellite port is giving 3.3V, while BEC is operating usually at 5 - 8V.
1.3 Wiring example
2 Liste der getesteten Sensoren
The following are known to work well.
Elektromotoren
Nitro und Gasser Motoren
3 Activation
First from all basic settings are necessary so the governor can control the head speed correctly. Please review all the parameters prior any configuration.
Fine-Tuning - Holding Limit
5 Throttle Channel verification
6 Electric motors - ESC Setup
6.1 ESC Throttle Calibration
  1. Turn off Spirit Governor in order to perform Throttle Calibration.
  2. Set linear Throttle curve in your radio transmitter so that 0% and 100% throttle position matches with value of the Throttle bar in the Diagnostics tab. If it is not matching, use Subtrim function in your transmitter and/or Travel Adjustment function.
  3. Re-calibrate Throttle Range according the instructions of your ESC. In the most cases it can be configured by powering the model with throttle stick with 100% throttle and then by moving the stick down to 0%.
  4. Now you can enable Spirit Governor again.
6.2 ESC setup
7 Combustion motors - Throttle Servo Setup
9 Governor Setup Procedure
10 First start
11 Autorotation Rettungsfunktion (Bailout)
Für jene Piloten, die Autorotationen durchführen, kann die Rettungsfunktion (Bailout) sinnvoll sein. Diese Funktion ermöglicht es, den Motor schnell auf die Flugdrehzahl hochzudrehen, wenn nötig. Sie können die Autorotation Bailout rate in den Advanced/Expert settings ändern.
Damit es funktioniert, musst du nur deinen Sender einstellen.
  • Bei der Autorotation nicht Throttle Hold betätigen.
  • Verwenden Sie stattdessen einen zugeordneten Schalter, der die Gaskurve zwischen 12 - 50% einstellt.
Info.png Wenn die Gaskurve unter 12% fällt, wird normal hochgedreht.
12 Throttle Hold für Autorotation (optional)
Falls Sie nur Throttle Hold für die Autorotation verwenden möchten, führen Sie bitte folgende Schritte aus:
  1. Setzen Sie die Gaskurve für Hold auf 12%. (Dies wird den Motor hochdrehen)
  2. Verringern Sie General/Governor/Throttle Range - Min., bis der Motor vollständig stoppt.
  3. Erhöhe die Spoolup Rampup bis du ein sofortiges hochdrehen bekommst, wenn Hold entschärft ist.
13 Fehlerbehebung
  • Eine Verzögerung zwischen dem Ausschalten von Throttle Hold und der Motordrehung - Motor beginnt nach kurzer Zeit zu drehen.
Vergewissern Sie sich, dass Ihr Gasbereich korrekt konfiguriert wurde. Hast du den Gasbereich mit angeschlossenem Spirit kalibriert?
Wir empfehlen den ESC auf Werkseinstellungen zu setzen. In den meisten Fällen entspricht der Standardbereich dem vorkonfigurierten Bereich im Gerät (1100μs - 1900μs).
Wenn der Bereich korrekt konfiguriert ist, aber es noch eine spürbare Verzögerung gibt, erhöhen Sie bitte den Parameter Spoolup Rampup bis der Motor sofort nach dem Ausschalten des Hold-Schalters zu drehen beginnt.
  • Motor ruckt nach dem Ausschalten des Hold-Schalters, was eine unerwünschte Drehung des Modells verursacht.
Verringere den Spoolup Rampup Parameter bis das rucken verschwindet. Wenn Sie eine Verzögerung vor dem Hochlaufen bemerken, ist der Wert zu niedrig und es muss eine andere Lösung verwendet werden. In diesem Fall kann das Problem nicht durch irgendwelche Einstellungen der Spirit-Einheit gelöst werden.
Überprüfen Sie, ob der ESC einen Spoolup Power-Parameter (Anlaufstrom) unterstützt. Wenn es unterstützt wird, dann versuchen Sie, den Anlaufstrom zu verringern und beobachten, ob es Ihnen geholen hat. In einigen Fällen kann eine andere Timing- oder PWM-Frequenz helfen, aber immer sicherstellen, dass die Einstellungen für Ihren Motor zulässig sind.
  • Nach anspruchsvollen Manövern wird die Kopfgeschwindigkeit über einen längeren Zeitraum bei höherer Drehzahl gehalten.
Vergewissern Sie sich, dass der Gasbereich Ihres ESC oder Throttle-Servos richtig konfiguriert ist. Normalerweise wird das Problem durch überschreiten der Grenze für den maximalen Gasbereich verursacht, die durch den Wert Throttle Range - Max. definiert ist. Wenn zum Beispiel die obere Grenze im ESC auf 1800μs programmiert ist, aber das Gerät 1900μs konfiguriert hat, dann wird das Gerät 100μs über die reale Grenze sein. So kann es bei einer hohen Belastung einige Sekunden dauern, bis der Wert in diesem Fall unter 1800μs sinkt.
Die Richtige Lösung ist, den Gasbereich entweder im ESC oder im Gerät neu zu konfigurieren.
  • Es gibt oft "RPM Sensor data are too noisy" (RPM Sensordaten sind zu verrauscht) Ereignis im Flugprotokoll.
Vergewissern Sie sich, dass der Anschluss des RPM-Sensors in Ordnung ist. Wenn der RPM-Sensor vom ESC getrennt ist, schließen Sie bitte seine Stromversorgung (insbesondere den Erdungsdraht) so nah wie möglich an die RPM-Signalleitung im Gerät an. Die Verwendung eines Ferritrings für die Stromversorgung könnte auch ein Rauschen reduzieren. Überprüfen Sie die Betriebsspannungsanforderungen für den Sensor. Einige Sensoren benötigen 3,5 V oder mehr, so dass sie nicht vom Spektrum-Anschluss des Gerätes versorgt werden können. In einigen Fällen wird es durch einen zu hohen Governor Response Wert verursacht, weil Motor beginnt zu jitter.
  • Der Governor schaltet nicht zwischen verschiedenen Gaskurven.
Ihr Gasbereich im ESC ist falsch kalibriert - der Bereich, für den das Gerät programmiert ist, entspricht nicht dem Bereich des ESC. Eine korrekte Kalibrierung des Bereichs wird das Problem lösen.
  • RPM-Signal war verschwunden.
Wenn der Governor das Signal verliert, wird das Ereignis innerhalb von 2 Sekunden erkannt. Der Governor wird noch funktionieren, aber mit verschlechterter Leistung - ähnlich wie bei einer V-Kurve. Dieses Ereignis kann passieren, wenn die Signalkabelverbindung fehlschlägt. Aus diesem Grund empfehlen wir Ihnen Heißkleber, oder eine andere Möglichkeit zur Sicherung der Anschlüsse zu verwenden.
