SpiritRS Mounting
Revision as of 13:24, 6 October 2021 by FuzzyBot (Talk | contribs) (Importing a new version from external source)
1 Unit Mounting
Correct mounting of the Spirit RS unit plays an important role for the operation of your model.
Find a suitable location where vibrations are as low as possible - this is usually the same location shown by the manufacturer for mounting a gyro.
It is VERY important that the unit will be mounted so that the unit is exactly perpendicular to each rotational axis. Depending on your preference and available space it can be mounted in eight different positions:
  • Horizontal (0°)
  • Horizontal (180°)
  • Horizontal (0° + inverted)
  • Horizontal (180° + inverted)
  • Vertical (0° - left side)
  • Vertical (180° - left side)
  • Vertical (0° - right side)
  • Vertical (180° - right side)
Mounting examples
Example 1: Position is Horizontal (180°)
Example 2: Position is Vertical (180° - left side)
In order to better insulate against any vibrations from the model, it is necessary to choose the right double-sided mounting tape. The tape should limit any transmission of vibrations from the model to the Spirit which may produce undesirable flight characteristics. Vibrations may also be caused by incorrectly balanced blades, damaged bearings, bent shafts and other mechanical issues.
2 Antenna
Spirit RS, GTR is equipped with 2 full-range antennas. For the best signal reception it is necessary to mount them properly at the model.
Ideally ends of the antennas should be perpendicular to each other in all directions.
Warning.png Do not bend antennas more than 45° in a sharp angle. Bending radius should be more than 2 cm.
Warning.png Do not cover antennas with any additional objects. Preferably direct visibility at any angle should be achieved.
