Spirit RPM Sensor
Revision as of 10:41, 23 November 2021 by Admin (Talk | contribs)
čeština • ‎Deutsch • ‎English • ‎español • ‎français • ‎italiano • ‎русский
This sensor is HALL type which senses RPM by motion of the rotating magnets. Usually 1 - 2 neodymium magnets are mounted on the fan of combustion helicopters with a Nitro motor.
Wire layout
Orange wire: RPM Output Signal
Red wire: Ground
Brown wire: 3.3V - 15V
1 Wiring Example
2 Magnet mounting
We highly recommend to orientate each magnet as Active for a proper operation. More magnets will result in a higher reading resolution thus increased readout precision.
3 Governor Settings
When sensor is connected, please set the Sensor Divider parameter so that the value will represent count of the active magnets. Usually it is 1 or 2 magnets.
