GeoLink Mounting
Revision as of 00:06, 16 January 2022 by FuzzyBot (Talk | contribs) (Importing a new version from external source)
1 Mounting at the helicopter
  • Horizontal (0°) - connector is pointing to main rotor
  • Horizontal (180°) - connector is pointing to tail rotor
1.1 Where to mount
  • It has clear sky visibility
1.2 How to mount
Warning.png Do not cover GeoLink connector with any tape, glue or paint. Opening above the connector is used to determine ambient pressure and altitude.
1. Take the first piece of tape and put it approximately in the middle.
1.4 Unmounting
1.5 Mounting examples
1.5.1 LYNX Oxy 2
LYNX Oxy 2
1.5.2 KDS Chase 360
KDS Chase 360
KDS Chase 360
KDS Chase 360
1.5.3 SAB Goblin 700
SAB Goblin 700
SAB Goblin 700
2 Wiring
Wiring with Spirit Pro unit.
3 Alignment
3.1 Alignment procedure
  2. Power up the Spirit unit.
