GeoLink Logging
Revision as of 07:23, 6 September 2022 by Admin (Talk | contribs) (Created page with " == <translate><!--T:11--> Logging</translate> == <translate><!--T:12--> GeoLink is logging each flight and stores the logs in its memory. It is storing every second while to...")
1 Logging
1.1 Logging specification
  • Up to 1.5 hour
  • Up to 63 logged flights
  • Recording period: 1 second
1.2 What is being logged?
  • Position on Earth: Latitude and Longitude
  • Altitude: relative altitude from starting point
  • Speed: flying speed of the model
  • Heading: direction in which model is flying
  • Date and time
1.3 Log viewer
1.4 Log backup and sharing
