GeoLink Logging
Revision as of 07:23, 6 September 2022 by FuzzyBot (Talk | contribs) (Importing a new version from external source)
1 Logging
1.1 Logging specification
  • Up to 1.5 hour
  • Up to 63 logged flights
  • Recording period: 1 second
1.2 What is being logged?
  • Position on Earth: Latitude and Longitude
  • Altitude: relative altitude from starting point
  • Speed: flying speed of the model
  • Heading: direction in which model is flying
  • Date and time
1.3 Log viewer
1.4 Log backup and sharing
