GeoLink Geofence
Revision as of 08:03, 6 September 2022 by Admin (Talk | contribs)
1 Geo-fence
1.1 How it works
1.2 Usage
  2. To engage with assigned GeoLink channel - it is required to assign F: GeoLink Geo-fence function in the General/Channels to an available channel.
Info.png Please make sure that Geo-fence Area was defined. Four points must be programmed. The Spirit Settings will display right order to program all points.
1.3 Modes
1.3.1 On (1)
When On (1) is displayed it mean that at this point Geo-fence is engaged and flight area is restricted. The model will return upon exceeding the area to the center of the area. Then pilot have to touch the aileron or elevator stick in order to continue in flight.
1.3.2 On (2)
1.4 Programming at field
1.5 Programming at computer
The easiest is to program Geo-fence area directly from your computer. By selecting points at the Map you can set the fence.
  1. Go the Aid Tab and there click at the Set button in Geo-fence subwindow.
  2. Select 4 points at the map to program area in which the model is allowed to fly
  3. If needed you can set new area by clicking the Set button again.
1.6 Return Altitude
If you will set Return Altitude parameter to a non-zero value then model will automatically reach and maintain this altitude when the function is engaged. If you want to control collective pitch when this function is enabled it is enough to set 0 for this parameter.
