GeoLink Altidude Limit
Revision as of 08:09, 6 September 2022 by Admin (Talk | contribs) (Created page with "== <translate>Altitude Limit</translate> == <translate>If you are worried you will forget to engage the Rescue mode in time, this feature is what you are looking for.</transl...")
1 Altitude Limit
1.1 How it works
Altitude Limit is aid feature that can automatilly perform Rescue of the model as soon as it will drop under a specified altitude. Or it can stop the model ascending when it will reach specified maximum altitude.
Whenever the Altitude Limit feature is engaged it will perform Rescue first to notify you it was really engaged. At the same time you can use Altitude Limit as ordinary Rescue mode in case you forgot to engage it prior an unexpected situation.
It will perform Rescue always for at least 1.5 seconds. Then depending on resulting altitude it is turned off and pilot can continue in flight.
Altitude for the Hard Deck is programmed in two ways described in the Modes section above.
1.2 Usage
The feature can be engaged at any given time by a switch of your radio. We recommend to use a normal two-state or three-state switch for this feature. But first it is important to decide in which way the feature will be engaged as there are two options:
  1. To engage with Stabi function - in this case the feature is engaged when programmed Stabi function is engaged. This mean you do not need to assign any other switch than when used for e.g. Stabilisation mode. [LESS CHANNELS ARE USED]
  2. To engage with assigned GeoLink channel - it is required to assign F: GeoLink Altitude Limit function in the General/Channels to an available channel. [EASIER TO SET UP]
1.3 Modes
If Altitude Limit is engaged by assigned GeoLink channel there is possibility to use two different modes for activation. In the Channels window you will be able to see Function as On (1), Off and On (2) which is corresponding to 100%, 0% and special case -1% to -100% channel value.
1.3.1 On (1)
When On (1) is displayed it mean that Hard Deck altitude is programmed from the altitude in which the model presently is. In other words, if you engage the Altitude Limit when flying in 5 meters, the models will be automatically recovered whenever it will drop under 5 meters. This mode is very easy to set, because you do not have to set basically anything. And additionally you can program Hard Deck to any altitude at any moment even without landing.
1.3.2 On (2)
When On (2) is displayed it mean that Hard Deck altitude is programmed from the channel value itself. It is calculated based on the range -1% to -100% where -1% is used for the lowest altitude and -100% for the highest altitude that is nearly equal to altitude specified for Maximum parameter. As soon as you will enable mode On (2) you will also see exact hard deck altitude in the Aid Tab from GeoLink window. This will tell you in which altitude rescue will be performed. If you want to set the Hard Deck to be same each time as with older firmware version such as 3.4.1 then you are looking for this mode.
1.4 Triggering Acceleration
