GeoLink Auto Landing
Revision as of 08:15, 6 September 2022 by Admin (Talk | contribs) (Created page with "== <translate>Auto Landing</translate> == === <translate>How it works</translate> === <translate> It is enough to engage the feature and the model will land at the current p...")
1 Auto Landing
1.1 How it works
Once the model will land the collective pitch will remain at a neutral position (0° deflection). The motor will not turn off automatically. Collective pitch is controlled by the unit all the time. If disengaging the feature make sure the main rotor is not spinning anymore to prevent unexpected change of the Collective Pitch. Once the feature is disengaged the Collective Pitch and all the control will return to the normal behavior.
1.2 Usage
  2. To engage with assigned GeoLink channel - it is required to assign F: GeoLink Auto Landing function in the General/Channels to an available channel.
