GeoLink Logging
Revision as of 14:41, 15 September 2022 by FuzzyBot (Talk | contribs) (Importing a new version from external source)
1 Logging
GeoLink is logging each flight and stores the logs in its memory. It is storing every second while total flight log length can reach up to 5 hours. If the memory is exceeded it automatically delete old logs in order to store new one. Logged data are subject to change and could change in the future updates.
1.1 Logging specification
  • Up to 1.5 hour
  • Up to 63 logged flights
  • Recording period: 1 second
1.2 What is being logged?
  • Position on Earth: Latitude and Longitude
  • Altitude: relative altitude from starting point
  • Speed: flying speed of the model
  • Heading: direction in which model is flying
  • Date and time
1.3 Log viewer
1.4 Log backup and sharing
