GeoLink Return to Home
Revision as of 13:47, 15 September 2022 by Admin (Talk | contribs) (Created page with "Návrat domů")
1 Návrat domů
Return to Home function will take control over the model and move it to your Home position. Home position can be programmed to a fixed point or it can be a lift off point.
If it is fixed point, one can anytime program the position:
  • in the Spirit Settings by choosing the best spot at the map
  • with transmitter and assigned tri-state switch.
1.1 How it works
Once the feature is engaged the model will immediately change its direction to programmed Home destination, wherever it is. It can work also upside down, so it does not matter what the orientation is.
1.2 Usage
The feature can be engaged at any given time by a switch of your radio. It is important to decide in which way the feature will be engaged as there are two options.
  2. To engage with assigned GeoLink channel - it is required to assign F: GeoLink Return to Home function in the General/Channels to an available channel.
1.3 Modes
1.3.1 On (1)
Channel value 57% - 100% : When On (1) is displayed it mean that at this point Return to Home is engaged and model will move to the Home spot. This is what you might want to engage during flight.
Info.png Please make sure that Home spot was defined in the Map tab if using On (1) mode.
1.3.2 On (2)
Channel value -100% - -62% : When On (2) is displayed the unit is in a programming mode which allow to overwrite current Home spot to the new with position at which the model currently is. Change will affect all Banks - if used. Please note that it will not work if model is flying or if GNSS signal is very weak.
1.3.3 On (3)
Channel value -61% - -38% : When On (3) is displayed the unit is in a programming mode which allow to overwrite current Home spot to the new with position at which the model currently is. Change will affect only active Bank - if Bank Switching is used. Please note that it will not work if model is flying or if GNSS signal is very weak. This feature can be used only with Bank Switching, because you can program Home position differently for each bank.
1.3.4 On (4)
Channel value 27% - 56% : When On (4) is displayed it mean that at this point Return to Home is engaged and model will move to your Take-Off position. Take-Off position is programmed automatically during each Take-Off. This mode can be used stright with no Home position programming.
Info.png If you often changing flying fields then this mode is recommended for you.
1.4 Return Altitude
If you will set Return Altitude parameter to a non-zero value then model will automatically reach and maintain this altitude when the function is engaged. If you want to control collective pitch when this function is enabled it is enough to set 0 for this parameter.
1.5 New Home position
It is possible to program the Home position either with the Spirit Settings by selecting a point at the Map. Or there is possibility to use GeoLink channel to do so even if you are away from your computer.
The easiest is to set up On (4) mode which will always use Take-Off position for Return to Home. If you are often changing flying field then using this mode is the best.
