GeoLink Altitude Hold
Revision as of 13:47, 15 September 2022 by Admin (Talk | contribs)
1 Altitude Hold
1.1 How it works
1.2 Usage
The feature can be engaged at any given time by a switch from your radio. It is important to decide in which way the feature will be engaged as there are two options.
1.3 Modes
