GeoLink - Držení výšky
Revision as of 13:48, 15 September 2022 by Admin (Talk | contribs) (Created page with "Držení výšky")
1 Držení výšky
1.1 How it works
1.2 Usage
The feature can be engaged at any given time by a switch from your radio. It is important to decide in which way the feature will be engaged as there are two options.
1.3 Modes
