GeoLink Auto Landing
Revision as of 13:50, 15 September 2022 by FuzzyBot (Talk | contribs) (Importing a new version from external source)
1 Auto Landing
1.1 How it works
Model will land at the position where the feature was engaged. Firstly, the model will stop it's movement. Secondly it will start to descend until it will reach approximately 2 meter altitude. From this point it will be descending rather slowly and only in case that the model is not moving in other way. If the model seems to be unstable it is important to perform the Compass Calibration or Correction angle adjustment.
Once the model will land the collective pitch will remain at a neutral position (0° deflection). The motor will not turn off automatically. Collective pitch is controlled by the unit all the time. If disengaging the feature make sure the main rotor is not spinning anymore to prevent unexpected change of the Collective Pitch. Once the feature is disengaged the Collective Pitch and all the control will return to the normal behavior.
1.2 Usage
  2. To engage with assigned GeoLink channel - it is required to assign F: GeoLink Auto Landing function in the General/Channels to an available channel.
