Translations:GeoLink Return to Home/95/en
Revision as of 13:57, 15 September 2022 by FuzzyBot (Talk | contribs) (Importing a new version from external source)
Channel value -61% - -38% : When On (3) is displayed the unit is in a programming mode which allow to overwrite current Home spot to the new with position at which the model currently is. Change will affect only active Bank - if Bank Switching is used. Please note that it will not work if model is flying or if GNSS signal is very weak. This feature can be used only with Bank Switching, because you can program Home position differently for each bank.
