Spirit Settings under Linux
Revision as of 07:31, 6 October 2022 by Admin (Talk | contribs)
1 Installation
1. Download and extract archive from https://spirit-system.com page.
2. Go to the extracted directory with Spirit Settings software and click at the settings.sh.
3. Choose Run in Terminal or Execute option (depending on Linux distribution).
4. If prompted, enter your user password to create UDEV rule. (to allow access for the USB interface - this is needed only for the very first time)
5. Close the app and connect the USB interface to the computer.
2 Usage
Whenever you need, start the app by clicking the settings.sh file. The USB interface must be plugged in your computer before starting. If everything is OK, you will see a Device in the Connection tab.
3 Troubleshootinng
In case that the app will not start at all, please start QT5 library. In Ubuntu and Debian based system the package is called qt5-default.
You can install it also from terminal with a command: sudo apt-get install qt5-default
If it will not help, please contact us. We will help to make it work with any major Linux distribution.
