Stabi mode
Revision as of 07:06, 28 March 2023 by Admin (Talk | contribs)
Info.png It is possible to set a different functions between Banks.
It is possible to activate the Stabi/Function in the three different ways.
The latest one called Selected by Channel is the easiest one and is recommended if you have a radio with enough free channels.
  • Negative Gyro Gain
  • Separate channel
  • Selected by Channel (NEW)
1 Negative Gyro Gain
Info.png Gyro Gain is still used to set the rudder gyro gain. At the same time, positive or negative value will determine if selected function is inactive or active. So it is important to set the gyro gain properly for both normal flight and selected function. Usually same, but opposite values are fine (for example +60%/-60%)
  • Position 0: 50% (normal flight)
  • Position 1: -50% (selected function)
1.2 In the software
1. First step
2.Second step
1.3 Function vs Gyro
Function Gyro Gain Gyro Mode Flight Mode
Disabled 0 - 100% Head-Lock -
Stabilisation (Scale) 0 - 100% Head-Lock -
Coaxial 0 - 100% Head-Lock -
2 Separate channel
Channel configuration
  1. Open the General/Channels.
Function indicator
  • 0 - function is inactive.
  • 1 - function is active.
Info.png Gyro Gain can still change gyro mode (Head-Lock or Normal). Positive Gyro Gain value will activate Head-Lock mode always. Active Function and Gyro mode is always visible in the Diagnostic tab.
2.1 Function vs Channel
  • Flight Mode "-" mean that the function is inactive and a normal flight regime is on.
Function Channel Gyro Mode Flight Mode
Disabled -100% - 0% Head-Lock / Normal -
Rescue (Normal) -100% - 0% Head-Lock -
Rescue (Acro) -100% - 0% Head-Lock -
Stabilisation (Normal) -100% - 0% Head-Lock -
Stabilisation (Acro) -100% - 0% Head-Lock -
Stabilisation (Scale) -100% - 0% Head-Lock / Normal -
Coaxial -100% - 0% Head-Lock -
Disabled 0 - 100% Head-Lock / Normal -
Rescue (Normal) 0 - 100% Head-Lock Rescue
Rescue (Acro) 0 - 100% Head-Lock Rescue
Stabilisation (Normal) 0 - 100% Head-Lock Stabilisation
Stabilisation (Acro) 0 - 100% Head-Lock Stabilisation
Stabilisation (Scale) 0 - 100% Head-Lock / Normal Stabilisation
Coaxial 0 - 100% Head-Lock Stabilisation
3 Selected by Channel
This option is the last in the Stabi/Function menu. First you have to set this option and then select F: Rescue or F: Stabilisation in the General/Channels. You can engage multiple functions at any moment in this way without need to use Bank Switching.
When two or more functions are enabled at the same time then only one function is working. Priority is following:
  1. Rescue (Acro)
  2. Rescue (Normal)
  3. Rescue (Automatic)
  4. Coaxial
  5. Stabilisation (Scale)
  6. Stabilisation (Acro)
  7. Stabilisation (Normal)
In other words Rescue (Acro) has the highest priority. For example when Stabilisation (Normal) and Rescue (Normal) are active, then Rescue (Normal) will be in operation.
↑Up↑
