Translations:GeoLink Troubleshooting/37/en
Revision as of 07:44, 4 April 2023 by FuzzyBot (Talk | contribs) (Importing a new version from external source)
- Enable Servos / Subtrim (tuning)
- At this point all servo arms must be in the center of their travel range. As close as possible - any visible deflection is not correct.
- At the same time swashplate must be perfectly level - you can check it really precisely only with Cyclic Leveler tool.
- At the same time there must be 0° between main blades. You can fold ends of the main blades so they are near each other. They must be at the same height wherever you will rotate with main shaft.
- Only after checking that all 3 are correct, verify that Geometry 6° parameter is configured precisely.
