SpiritW1 Telemetry
Spirit W1 is equipped with 2 separate inputs for Spirit Telemetry sensors. These sensors are compatible also with external Spirit RX receivers.
Available telemetry ports:
- T1
- T2
Please note these ports are not used for ESC telemetry or GeoLink module.
Spirit W1 is equipped also with X pin at T2/RPM/X port. This pin is used internally for communication with built-in receiver. When using Spirit RX receiver nothing should be connected to X pin.
1 Telemetry Sensor Wiring
1.1 T1 port
Connect Sensor or Expander cable directly without any change.
1.2 T2 port
Connect Spirit Sensor cable in so that RED/BROWN wires are at the AUX port (or any other free powering port) and ORANGE wire at the bottom T2 pin. In case of lack of free ports, please use an Y-cable.
Original connector must be modified so that two servo connectors are used.
2 Telemetry Sensor Data
You can set display Sensor Data at the Main screen by opening adding Widgets.
3 Spirit Telemetry
Besides Spirit Telemetry sensors you can also utilize the ESC Telemetry, GeoLink module and Spirit telemetry variables.
This mean you can interface your ESC and display telemetry data such as Battery Voltage, Current, Consumed Capacity, Temperature, RPM.
For more details about ESC telemetry please visit linked guide.
Similarly you can install GeoLink for measuring GPS position or Speed and other variables.
