SpiritW1 Preparation
Revision as of 12:56, 9 January 2024 by Admin (Talk | contribs)
To use Spirit W1 with Spirit Wave radio it is enough to create fresh Model in the Model list.
Spirit W1 unit can be used for Helicopters and Airplanes. Depending on this create according model.
1 Model Creation
1. Go to Main Screen by tapping at the Home icon from where you can enter Model Selection menu.
2. Tap at the Create button and choose Yes.
3. Then select Helicopter or Plane and enter Model Name if using Spirit W1.
Info.png By default Spirit W1 units are preloaded with Helicopter firmware. You can flash Spirit Aero firmware for free at any moment if you plan to use a plane.
2 Model Configuration
All Model-related settings are at the Model menu (Third icon at the bottom panel).
Depending on Model type you selected during model creation this menu has differences. For helicopters you will find there different menus than for a planes.
2.1 Model menu pages
After binding with Spirit W1 you can find three menu pages in the Model Menu. If Spirit unit is not detected only two menu pages are visible.
  • Spirit - Full integration and configuration of the Spirit Flybarless unit.
  • General - Receiver binding, Flight Modes, Throttle and Pitch Curves, Gyro gain and similar.
  • Miscellaneous - Theme for particular model, Alarms, Logging and rest.
