Spirit Wave Intro
Revision as of 11:57, 24 October 2024 by Admin (Talk | contribs)
1 Introduction
Each Spirit Wave R/C transmitter comes fully calibrated and tested in a real condition to allow immediate operation. Our aim is to provide product with a high quality standards and long operating time with extended support. All inputs such as Touchscreen Display, Switches, Potentiometers, Sliders, Motion and Light Sensors together with Sound System check are passing through extensive tests prior the shipping. Each RF module is strictly tested to meet desired parameters.
Our products are completely services by us or by authorized Spirit Wave dealers. Each Wave radio has 2-Year Warranty.
1.1 First Steps
We highly recommend to Charge Radio Battery first. Spirit Wave comes with LiPo battery at Storage Voltage to make sure it can be left for long time before use. Charging can be done in the same way as todays Smartphones through USB-C connector with no special requirements. USB Charger is not part of the Package Content to allow easy Worldwide distribution and minimize environmental impact.
Charging will Stop automatically to prevent overcharging.
1.2 Charging
Charging can be performed at any moment. Radio will start with the process immediately if Battery Capacity is under 100%.
  1. Insert Charger to the Grid or a Charging cable to a source (Computer, Power Bank).
  2. Insert USB-C connector at the rear side of the Wave radio.
1.2.1 Charging Status
  • When radio is Powered Off you can find whether it is charged or not by short press at the "S" Button. When battery is being charged the "S" Button is pulsating.
  • When radio was connected to the Charger while Powered On you will see Charging notification immediately at the Display. Display will show you Battery Capacity all the time.
Info.png If radio is Powered On Charging speed is several times slower depending on user activity.
1.3 Powering On
  1. Press and Hold "S" button for at least 3 seconds.
  2. You will feel short vibrations, button can be released.
  3. Radio will Bootup within following 5 seconds from Cold Start.
1.4 Powering Off
  1. Short press at the "S" button,
  2. Confirm the intention by pressing YES at the Display.
Info.png You have to confirm Powering Off within 5 seconds.
Info.png If a model is connected Radio will Display Warning and will not allow Powering Off without further interaction.
1.4.1 Force Shutdown
In Emergency, unexpected situation it is possible to completely Power Off Wave Radio by Long Press and Hold at the "S" button for 10 seconds. After 10 seconds "S" button light will turn off and you can release the button.
