Spirit Wave Specs
Revision as of 07:15, 11 June 2026 by Admin (Talk | contribs) (Marked this version for translation)
1 Specifications
1.1 Base Data
1.1.1 Specification
  • Weight: Wave @ 865 grams +/- 10g, Wave Pro @ 1110g +/- 40g
  • Main Body dimension: 180 x 170 x 65 mm (excluding Radio Holder, Switches and Neck Strap Lock)
  • Operating Temperature: 0 - 40°C / 32°F -104°F
  • Battery: 6900mAh 3.8V Premium Grade LiPo
  • Current Consumption: 850 mA max., 45 nA Standby
  • RF Power: 380mW max. (depending on Country)
  • WiFi: 2.4/5 GHz b/g/n/a/ac
  • Bluetooth: BT/BTLE 5
1.1.2 RF Module specification
  • Frequency range: 2400–2483.5 MHz
  • Maximum EIRP: 20 dBm (for EU countries)
  • Modulation: O-QPSK
  • Antenna gain: 3.3 dBi
1.1.3 WiFi & Bluetooth specification
  • Maximum EIRP: 18.2dBm
  • Modulation: BPSK, QPSK, 16QAM, 64QAM, 256QAM
  • Antenna Gain: 2.4GHz: 3.5dBi, 5GHz: 2.5dBi
1.1.4 Supported Models
  • Helicopter
  • Plane
  • Copter
  • Car
  • Boat
  • Other
Info.png Model Support will be extended with upcoming updates (Free Of Charge).
1.1.5 Package Content
  • Spirit Wave transmitter
  • Carry Bag
  • Neck Strap
  • 2m USB-C Cable
  • Alan Key
  • Torx T6 Key
Warning.png USB Charger is not included, you can buy it optionally from us. Any smartphone/tablet USB (USB-A) charger will work, including USB port from a computer. Do not use a custom power supply to charge the battery!
