Altitude Hold
Revision as of 07:01, 13 July 2026 by Admin (Talk | contribs)
čeština • ‎Deutsch • ‎English • ‎français • ‎italiano
1 Altitude Hold
For automatic maintaining altitude of the model you can use this function. It works with Spirit 3, Spirit W3, Spirit GT and Spirit GTR without need of connecting any other peripheral. Operation is based on internal Pressure sensor that can sense altitude during flight.
1.1 How it works
To enable this feature it is required to set F: Spirit Altitude Hold at the General/Channels - right side.
1.2 Usage
The feature can be engaged at any given time by a switch from your radio. It is important to decide in which way the feature will be engaged as there are two options.
1.3 Modes
There are following modes available, depending on channel value. In the Channels window you will be able to see Function as On (1), Off and On (2) which is corresponding to 100%, 0% and -100% channel value.
When On (2) is displayed it mean that altitude in which the feature was engaged will be held. Pilot is unable to change Collective Pitch by pitch stick. So that Collective Pitch steering is fixed and is changed only by Barometer in order to hold right altitude.
2 Safety
Although Spirit unit is automatically changing Collective Pitch in this mode, it is always required that pilot have full control over R/C model. Pilot must always watch the model while holding radio transmitter and to not allow flying anywhere where a damage could occur. All functions that the module provide can be turned off at any time and with no delay so that pilot can steer the model normally. Improper operating conditions can lead to a failure of the system.
Altitude Hold can be used for the most 3D maneuvers, however holding precision is very dependent on model, Spirit mounting position and ambient pressure variation. The best precision can be obtained so that after each maneuver pilot is waiting until altitude is stabilized. If maneuver takes longer time while Collective Pitch is changing often, measuring precision is significantly lower.
Warning.png The user takes full responsibility for any damage or injury caused while flying an R/C model equipped with one of our devices. The manufacturer can neither guarantee nor control the conditions in which the unit is being used.
